Hi All,
I have implemented the ASP.Net 2 version of FCKEditor. All seems to beworking correctly other than the 'Browse Server' function.
What this function is activated, I receive the fo...
I built a drupal site, development was done on hosts url (http:itk.ca.previewyoursite.com)
Our domain is itk.ca
Once site was built, I set up DNS with the registrar so www.itk.ca should work...
Hey guys,
I had a skin created for me and I modified it a bit and wanted to add a SWF music player to the top of my page:
www.elementsofdance.ca/dj/Portals/_default/Skins/NEW/skins.html ...
I'm building a new site on the Joomla content management system, v1.5.4. I've installed an extension called EventList 1.0 beta from http://www.schlu.net/.
The EventList control panel allows...
I have a Joomla 1.5.6 site that's painfully slow, both from the front and back ends. I think I know why this is, but being that I'm new to content management systems generally and Joomla speci...
When I create a story or page, and put it on the front page, it shrinks to a condensed version with a "read more" linik. I'd like some of my stories and pages to show FULL. How do I specify ...
I have a page in my DNN site having the url
http://www.mysite.com/default.aspx?tabid=68&co=123abc
where co is a query parameter
I need to build a friendly url for the page such as
http:/...
Hi guys, im searching for a CMS solution for a social network that would allow for video uploads / photo uploads / profiles / posting of links with the cURL function that will take the link an...
OS: Vista
Browser:IE7
CMS: Joomla 1.5
Issue:
I created a template for joomla. I copied the php from rhuk_milkeyway to insert the modules in the places I needed them. I created all the di...
I am wondering how to modify my html code to add a drop shadow around the content area. I use a content management system through a company called INSPYRE. So, I don't use a standard ftp uploa...
Hi i want to remove the fields timezone and language from the phpbb3 registration? Can this be done? Thanks James
We have a client with a HTML site that they want to convert into Joomla so they can use Joomla to manage content, etc.
Does anybody know of tutorials that can help me out?
I'm using a module called YOOmaps 1.5.5 with an Install of the Joomla content management system v1.5.4. The map works perfectly except for an odd error message at the very bottom, under the Ge...
I was working on an add-on component for Joomla when I realised the drop-down links backend weren't working. A view source shows there is no link, just <a></a> and text in between.
3 error...
I am using Joomla to design a web portal and I have few questions regarding session management:
This is what I need:
- Will it support multiple users logging in and logging out
- Need t...
I was wondering if anyone would strong;y recommend for or against pursuing the ExpressionEngine as a low-cost CMS solution. Is there something in the same cost range that is consider...
We are using ASP.net 2.0 for developing a website. In our application we use FCKEditor Ver is 2.2.2952.27793 and CKFinder 1.0.1.20567. We are using FCKEditor for adding contents(in admi...
what does these error mean? I got it when installing a module in Drupal.
thanks
warning: include_once(modules/simple_access/inc/admin.inc) [function.include-once]: failed to open stream...
My first Joomla 1.5.7 website.
I want to insert a table in an article.
I see how to insert a table, and how to merge cells. But how do I resize cell sizes (or can they automatically resi...
Hi, i was changing some options on some menus in joomla backend, and suddenly i noticed the the website was blank viewing in firefox. I have no idea what is wrong. Can some one help me.
htt...
Hi i have got wondershare quiz maker and have outputted the file to a webpage but cant seem to integrate it in joomla.
It has outputted the following files:
swg.js
test.html
test.swf
I don't want to use the built in Registration facilty with Joomla 1.5's Log-in module. I need to know how to change the query associated with the Phrase "Create an Account" from it's default:...
I'm creating a CV page for a professor using Drupal. He gave me a PDF file and ten images (scanned certificates and books) but I have no idea how to create a page with them.
My i...
hi everyone, i alredy installed web based CMS (mambo 4.6.5) and i wish to use a good forum, such as phpbb, so after some web research, i saw problems with database (conflicts) with user accou...
I'm using Plesk 8.4.0 w/LAMP, and I would like to be able to access my sites via localhost. I can currently reach my sites by typing in their domain, but what I'm trying to do requires an addr...
